Hey all, a weird glitch… My Auto Clearfix 7
error kept popping up.
so I deleted the 7 action and reinstalled it, thinking maybe it needed updating… but now it is not visible in palette nor in the list of actions
it is however in the library/ application support FWPro action folder.
I have restarted etc, looked through the actions nada
update - I just added the action again through Install Actions palette, and looked to see if the 2 auto clearfix actions are there. both 6 version and the 7 were next to each other. then I closed and reopened and 7 was gone.
if anyone can help with this would be great. I can’t reach Softpress as its a weekend
thx
all
after about 7 attempts of trying to install clarify action here is what I did
went to app support in library, deleted the clarify 7 action, then reinstalled it. restarted FW and it was finally there. so it seems it was important to delete the action in library or it would not install.
But its not over… after I applied the action to my site, which has worked perfectly while its newly built. the error continues
blah
fyi - this clear fix error happens often enough to be frustrating
