Richard,
Regarding the two-column module, what happened is that the columns (twoLeft and twoRight) got out of order. If you look in the Freeway sidebar, you will see that the standard two column module has a construction like this:
Now, if you look at your module, you will see this:
This is the source order. When Freeway outputs HTML, it writes them in that order in the HTML file. When everything breaks down into a single column on a webpage, the elements will follow the source order exactly.
You accidentally changed the source order of the columns in the module. This is very easy to do – Freeway has an annoying habit of interpreting and small/accidental cursor drag as a request to reorder the source order.
To restore your module to the default setup, do this:
- Select the
twoRight
element in the sidebar.
- Copy it to your clipboard, and delete it from the document.
- Click on the
twoLeft
element.
- Press the → arrow key on your keyboard once. This will insert your cursor directly after
twoLeft
- Press ⌘V to paste
twoRight
back in.
- Check via the sidebar to make sure that they are not in the proper order.
Once you have that done, float twoRight
to the right again. This way it aligns on the right side of the module wrapper, as it should.
Regarding the body tag this too is as the template and unaltered by me so Caleb’s explanation for that should clarify the quirky.
This is what your body tag currently looks like…
<body style="style background-size: cover; background-size: cover;">
And this is Backdraft’s default body tag…
<body style="-webkit-text-size-adjust: 100%;">
And this is what this should look like if you want the background-size to be set to cover
<body style="-webkit-text-size-adjust: 100%; background-size: cover;">
So, it does look like you made some modifications to it and accidentally malformed it. Here’s how to fix:
- In Freeway, go to Page > Extended.
- Delete the existing entry.
- Add a new entry with
style
as the name and -webkit-text-size-adjust: 100%; background-size: cover;
as the value.
