Justin, you’ve got a style sheet applied too all other (the ones I’ve looked at) pages (usually) called index_override.css that doesn’t appear on this one
These files (whatever+_override.css) come from any Action that uses my CSS modification library. So Carousel2 or another Action like that will add this file (not just mine, Paul Dunning uses this as well). If you are not using one of those Actions on that page, then it is entirely reasonable that you would not see that _override file on the page.
On Aug 3, 2013, at 8:37 AM, Justin Easthall wrote:
Thank you!
So FW isnt producing this? How can I get it to produce it? - Im not creating any index_override.css?
THANK YOU!!! Sebatian! Worked a treat God knows why how or when this started to happen - Freeway has been driving me nuts on this project - failing masters, images swapping out - BAM menu nothing but a pain etc etc
No worries Justin. The reason why this is happening is because the two examples you posted (working & non-working) are inside different directories on your server. /w1 & /w1/Workitect Agendas and thats why the original link in your header did not work.
Nothing. It’s just linking back to the css file one directory “up” from the one its being served from. I was just trying to explain why your old link didn’t work.
Oh right thanks - a cache thing. Cant wait for this job to end!!! So tired of FW and its kinks. Why this is doing this in the first place? Spent so much extra time (money) solving all these problems.
