Does anyone else incorporate a page turning solution into their site/s?
I have see services such as: http://www.vfolio.co.uk but just wondered if there were any better / more efficient ones out there that others have had experience with.
I use one from these folks, http://page-flip.com/
It required a little bit of html work, which I don’t know much of but was able to work my way through with relative easy.
Had to go back and review since it has been about 6 months since I first downloaded.
I had to use the, basic HTML addition, http://page-flip.com/products/flippingbook-html-edition/
Which does require you to open up some of their html and insert your new pages and mess with settings until you get the result you are after. If you are like me and are not well versed in html/coding, expect to spend a couple of hours figuring it out…
I did a bit of research on this before I went with this product and it seemed to be the most cost effective way to get it done.
Also, looks like they changed their prices, 1 website is free with the basic html addition, unless there is some fine print.
I paid $69 a few months ago.
Thanks Rich, I don’t have a problem messing with html so might take a peak at that!
Nathan Garner
Creative Director
Austin Wells Design Limited
One Elmgate Drive - Littledown - Bournemouth BH7 7EF
t 01202 301271 e email@hidden w http://www.austinwellsdesign.co.uk
Member of NAPP | Zen Affiliate | Dorset Business Member | YEC
Facebook | Twitter | LinkedIn
