Beta 2 of ScriptyFader for Freeway 6
Updated, fixed the inline usage issue (positioning should be exactly correct now), removed a bunch of cruft related to the first-generation Scripty Actions.
This has only been tested in Freeway 6, I would appreciate some brave folks looking at it in Freeway 5.6 or earlier.
To install, follow this link: https://gist.github.com/walterdavis/5842189/raw/bd3badcaa7a2d80f6adb02286ccacdf5e6ee7d6c/ScriptyFader.fwaction
In your browser’s File menu, choose Save As… and put the file somewhere you can locate. Then rename it (if you’re using Safari) from .fwaction.txt to just .fwaction. Drag the resulting file into your Actions folder and you should see a Replace existing file? warning message. Okay that.
I will post this in a more accessible form when I get a chance.
