Sometime around 16/2/08 (at 01:09 +0000) Pete MacKenzie said:
One thing I have noticed - if I import an image into a graphic item,
resize it by Scale and Trim and then change my mind and import a
second image I end up with a tiny lo-res image in the top left corner
of the graphic item. Re-importing produces the same result. If I then
do a fit to frame type command the result is massively pixellated but
fills the frame. However, import again, after this resize and the
result is a properly rendered image. A bug?
Actually no - this is all quite logical when you examine all the
details of how things work. It is also the way Freeway 4 and earlier
has worked.
First of all, when Freeway imports an image it will, unless told
otherwise, pay attention to the embedded ‘per inch’ resolution
setting. An image set to 300ppi for print work will import at the
same relative scale on your Freeway page. You can of course scale it
up, and the result will be recalculated from the full original image
data, from the file on your hard disk.
This recalculation isn’t done until you either ask for it explicitly
(click the Resample button in the Modify dialog) or preview/publish
(at which point Freeway checks the original imported image files).
Until then, a scaled-up image will just show the embedded preview
image data, enlarged and pixellated. Double-click and click Resample
for the quickest way to sort this out.
Why isn’t this done on the fly? Well, you may have large original
images placed on the page, which could cause significant lag if every
scale and crop action required reimporting fresh pixel data.
When you scale an image in a graphic box in Freeway, the box
remembers the scale. If you import another image right over the top
of that one, the scale settings are preserved. This is a subtle but
wonderful thing, as you can have a whole set of image files ready
for use, set up a box with the desired scale, then duplicate it and
drop in a new image… presto, it is scaled just the same!
If you don’t want the image scale to be remembered, clear the image
before importing a new one. When the image is removed, so is any
scaling setting. And as Jeff said, the way to do this is to choose
Edit > Clear Content, or type command-B.
(I really should start writing this stuff up in one document.)
It would be nice if one could
select content separate from the container as in InDesign for example.
We have something similar to that without needing the two-tool
approach. Content can be dragged around in a frame, transformed
together with or independently of the frame, and with the Clear
Content command there’s little more that we really need. It is more a
matter of slightly different approaches than major difference in
ability.
k
Freeway5beta mailing list
