I use the final FW5 (after having build a complete site with the Beta)
Suddenly the list of h1 styles grows. huh? They are all the same. I did not do anything there.
When I delete (and replace naturally) the surplus, the app crashes. Not once, no three attempts now.
When I copy and paste a HTML element (with this h1 style applied to a piece of text inside it) FW in all her wisdom adds, completely without my authorisation, her own h1 styles. Now I end up with sixteen of them. Some called h1style1 h1style2 etc. When trying to delete them, and replace them with my own original carefully crafted h1 style which has been in function the last three weeks without any problem, the app crashes, leaving me alone staring at my desktop.
Would you be able to contact our support team support at softpress.com and they will look into the problem. We would very much like to repeat your crash if at all possible, as well as look into what is causing your problems.
Problem with nested HTML items inside cells in a table. FW creates extra styles when copy-paste this table inline in the document. Not good. FW crashes when deleting these extra styles. Even worse.
Softpress works on a fix, and I got advise how to remove the extra styleswithout the crash.
They say: Quote: Another workaround was discovered in fixing this problem. The problem is limited to the Edit Styles dialog, so open the Styles and Color palette from the Window menu and click the first tab.
Here you will get a list of the styles and can remove them while replacing the styles without any problem.
end quote.
I must say, FW support acted fast. Good to know what is going on.
