Well, you’ve got a mess of styles here. Some aren’t you’re fault and other’s need to be adjusted. First off, do you have to use % for your font-size? Perhaps you could set it to 12px or 14px for the general body size. It’s also easy enough to change the leading from 1.7 em to the PX equivalent. The browser age is not that dated and most browsers can read pixel measurements just fine.
For #nav2 ul item make sure you put in a right margin as well so in your extended palette you’d adjust it so it reads:
#nav2 ul { margin: 0 0 0.1px 0px; }
and the same with the li item it should read:
#nav2 ul li { padding: 5px 0; }
Now for the extra styles Freeway has a bad habit of creating new random styles starting with 1,2,3,4…etc and so on. To alleviate that problem you’ll have to double check which style is attached to what item. I’ll help with this part, style3 is attached to your article text in the middle. You could just drop that since your body tag could be changed to match that style of text. Style1 is attached oddly enough in a paragraph style that should have been adjusted by setting the default P tag in Freeway’s CSS palette to:
p { text-align: left; }
You could then make the color of the article text the default color in your body tag
body { color: #00009b; }
Style4 is attached to your footer on the bottom. That could be renamed as a class name of “footer” and left with just the white color and text align set to center.
So here’s the updated CSS look:
body { color: #00c; font: 12px/1.7em Verdana, Arial, "Lucida Grande", sans-serif; margin: 0; height: 100%; }
#nav2 ul { list-style-type: none; padding: 0; border-top: 2px solid grey; margin: 0 0 0.1px 0px; }
#nav2 ul li { padding: 5px 0; border-bottom: 2px solid grey }
#nav2 ul li a, #nav2 ul li a:visited { color: #f00; font-weight: bold; text-decoration: none }
#nav2 ul li a:hover, #nav2 ul li a:active { color: #0f0; font-weight: bold; text-decoration: none }
.footer { color:#fff; font-size:11px; text-align:center }
Remember also that if you want to style a specific DIV ID…say for instance “#right-col” to target the paragraph try writing the ID as:
#right-col p { }
That may help targeting those paragraph items more directly.
Hopefully that helped out, you just have mis-mashing styles but the good news is the changes are easy and you’re close to bringing it under control.
Good luck.
