dhrose
(dhrose)
November 13, 2007, 3:20pm
#1
Is there a way to calculate information entered in FW Pro fields, without linking to a database? Or is this accomplished with PHP or Javascript… I need to make a simple calculator. Thanks!
Yes, PHP or Javascript would be the first to look at.
David Owen
Printline Advertising ::
http://www.printlineadvertising.co.uk/freeway/
dhrose
(dhrose)
November 13, 2007, 4:10pm
#3
Thanks. So I guess I need to start coding.
chuckamuck
(chuckamuck)
November 13, 2007, 5:26pm
#4
Take a look at the following web site http://cs-people.bu.edu/stevec/cs101/01summer/forms_calc.html . It describes a really basic use of a calculation in a form using php. Maybe this isn’t what you had in mind.
dhrose
(dhrose)
November 13, 2007, 7:32pm
#5
Hmmm… link doesn’t work?
Javascript would just work on the page; PHP would have to submit to
the server and reload the page.
HP-UX specialist of hpUG technical user group (www.hpug.org.uk )
www.ivdcs.co.uk
waltd
(Walter Davis)
November 13, 2007, 8:07pm
#7
Right, and you would choose one over the other depending on whether
you needed to trust the results of that calculation. If it’s just a
convenience for your users, then go with JavaScript. It will be
faster for the users and less bandwidth used by your server.
chuckamuck
(chuckamuck)
November 13, 2007, 8:51pm
#8
Ooops. Just delete the period (full stop) at the end of the url.
