I have a person who wants to send me a Flash or Java Script crossword puzzle to be added to my site. I’ve seen his work and it’s top-notch. The crossword puzzles allow people to type on the answers right on the site.
I’ve dropped HTML code into my site before using the HTML Markup feature.
Flash is just a “noisy picture” from Freeway’s perspective. You can
drag it onto the page, size it and position it like any other art
element. JavaScript would depend a lot on the actual code, but you can
use the Markup Item to add a script on the page in a particular spot,
and the Page/ HTML Markup dialog to add library script to the HEAD
tag. Most JavaScript of any complexity will rely on a library of code
injected in the head along with a specific invocation of that code at
the spot in the layout where the visual output is needed, so you
probably will need to do both.
right on the site.
feature.
