I’ve just downloaded Freeway Express…!
Can I copy and paste from my iWeb site rather than re-writing everything?
Lynne
http://www.good4yoursole.co.uk
actionsdev mailing list
Text certainly - but you will need to restyle it within FW
As far as graphics go you are best to work from your originals - the ones on your site will already be compressed jpegs and you don’t really want to compress them again by processing them in FW
If you have Photoshop psd or tiff files they are the best starting point and will produce the best image quality on output.
If you only have the web ready jpegs then use them as pass through images if Express allows - not sure of FWEs limitations here.
BTW the Actions Dev section is not really the best place to post this sort of question as it is less well trawled as the main Freewaytalk section
Thanks Dave
That will save me a lot of work!
I’m new to FW (as you can probably tell)! So I clicked all the boxes for mail… I’ve unchecked them all now as I got about a million emails!
Thanks again for your time
Lynne x
