I have purchased a small number of Webfont (3rd party web-safe fonts) from MyFonts (ITC) and a family of fonts from Linotype, and I cannot figure out, understand how to properly store them into Freeway Pro 6.1.2 so I can use them.
Also, strangely, all of the actual font files I downloaded after purchasing have numbers on the actual font files instead of font names and versions (for example: roman, italic, demi bold and demi bold italic, etc.)
The family of four “related” Linotype fonts include four files, each with its own “extension” one for each font - each having a different extension at the end of each (even though the font name is a number):
they are “.svg” / “.ttf” / “.eot” and “.woff”
The MyFonts font is an ITC font (Grimshaw Hand), and there is only one weight, and for some reason again there are again only a font files with the following suffixes at the end of each (and again, each font only has a number in place of a font name):
“.eot” / “.svg” and “svg_test.html”
Can someone help me please…
Also can you please explain which of these FOUR extensions are NECESSARY for a web font to work properly as such through Freeway Pro?
I would very much like to actually TALK with someone for several minutes, as I am totally lost regarding this - and cannot even begin to do any work on the site if the fonts I am to use are not available to me…
PLEASE GET IN TOUCH WITH ME ASAP.
Thank You,
Steven
48 Wilard Grant Road
Sudbury, MA 01776
USA
978-376-3783
