Capturing screen motion
I need to capture a clip of a programme rotating its graphic on screen. It’s a windows programe, rather specialist, which outputs cave surveys which can be viewed from all sorts of angles and be set to ‘spin’ i.e. rotate clockwise or anticlockwise.
For the purpose of a web site, I want to capture a few seconds of a survey spinning round and present it as a…movie? (or swf?)
Not sure if any users here would have experience of screen capturing on Windoze?
thanks, Hugh
Have a look at Camtasia – I think that’s the ticket.
on Windoze?
thanks, Hugh
anticlockwise.
Windoze?
I use SnapzProX, there are others:
http://www.ambrosiasw.com/utilities/snapzprox/
Best wishes Peter
Peter Tucker, Oxford UK email@hidden
Hi Walter, thanks for the tip.
Hi Peter, thanks too…but it’s a Windoze programme I need!
cheers
