For some reason I seem to struggle with Carousel navigation buttons, probably because I don’t do them enough.
What’s the best way to build navigation buttons into a website that contains a Carousel? Is it better to try to design an inline navigational wrapper to contain the buttons or simply use a layered box?
Also, I’m currently using the Carousel Tab Button action to make all of this work. Is that the best and easiest solution?
