Carousel tabs and buttons in IE6
I have a Carousel action that uses tabs and button together (you can click on either one). It works great in Safari and Firefox. In IE6, the buttons don’t do anything and the tabs don’t really carousel, but they just show the new pane.
Any way to get it to work in IE6?
Could you post a link?
Sure:
http://reeltimedvd.com/new_site/reeldeal3.html
The funny thing is it works fine in IE6 on this page:
http://reeltimedvd.com/new_site/coverflowl3.html
Thanks.
Try re-making your page so the tabs are not within the carousel
element itself. Look at the coda page for an example of what I mean by
that. http://panic.com/coda I’m not sure if that’s your specific
problem, but it’s worth a try. I suppose that the function that looks
to find the correct carousel to use with a particular tab is being
confused by this construction technique you are using.
On Feb 10, 2009, at 12:01 PM, george wrote:
Sure:
Thanks.
List Options | FreewayTalk
