Since Strict is a concept of HTML4/XHTML1, what about when FW outpus HTML5 or XHTML5?
#curious
Leif Halvard Silli
-----Original Melding-----
Fra: Walter Lee Davis
Sendt: 19.11.2013, 13:56
Til: email@hidden
Emne: Re: Closing tags with a /
Any single-ended tag will be closed with a / if you have set the page level to a Strict doctype. Otherwise, it will be that odd start-tag-only business that looks wrong.
On Nov 19, 2013, at 5:48 AM, Paul wrote:
A quick one - how do I close a tag generated by an Action with a / - e.g. <img … />?
XHTML5 includes the trailing slash in single-ended tags.
#curious
Leif Halvard Silli
Til: email@hidden
But when using HTML5-output, then FW does not do ?
Leif H
Walter Lee Davis, Tue, 19 Nov 2013 08:46:48 -0500:
HTML5 or XHTML5?
#curious
Leif Halvard Silli
Til: email@hidden
Leif Halvard Silli, Tue, 19 Nov 2013 17:06:43 +0100:
Paul, Tue, 19 Nov 2013 10:53:07 -0500:
I used ing as an example - I should have been more specific (sorry).
I’m adding in SVG, and SVG only works if the e is a closing / in tags.
Why do you need that, for SVG? Within , then per the HTML5
spec, it is OK to do both and .
Let me add that this is because lives in its own
(name)space, within a HTML document. So it has different rules from the
elements of the HTML5 vocabulary. (But you may of course have other
reasons for wanting to use the /> syntax also in SVG.)
I was finding that things weren’t drawing without the closing / in the tag. Anyway, I’ve got it working how I need it too - just that the tag tree is not complete.
Also noting that Leif’s sag tags are playing havoc with this thread in Safari.
Yes. I saw that. I don’t have time today or tomorrow to fix that, but it’s an easy fix in FreewayTalk.net – just need to add some more named tags to the converter.
