Steve,
i’m looking for some info about CMS! thanks but the link is dead, can you please upload?
thanks you,
Eldad
tutorials mailing list
Steve,
thanks you,
Eldad
Is the CMCMS tutorial still available anywhere? Will there be a part 2?
Thanks!
Peter
On 21 May 2007, 1:55 pm, sjgrafx wrote:
Here is part 1 of my tutorial for generating Freeway Templates for use in this Open Source CMS…
part 2 coming soon…
many thanks,
Steve.
Hi,
Can’t seem to get to this tutorial either - is it still available?
Tony.
I’ll be writing a tutorial for CMS Made Simple with a sample file in a little bit. Just gathering some resources and uploading some contents for it as I post.
Stay tuned!
It’s up!
The complete tutorial is posted at http://danjasker.blogspot.com.
There is an entire package there with a sample file, a 26 minute video showing how to do it all, and 2 existing actions. After watching the video I realized I missed the beginning part of talking about the actions applied to the document already. The two actions are the “Page Div Styles” and “Remove Paragraph Tags.” I dance around a bit of what they do later in the video, but for future reference apply these to your page first. The Page Div Styles will remove all inline styling from the DIV’s in your outputted code and then it will place them in a separate CSS document named to whatever you want. Make sure the file name ends with .css and the other “Remove Paragraph Tags” action removes all of Freeway’s generated paragraph tags for text.
Hope this helps and feel free to comment and enjoy!
Mitchell, your blogspot link does not work because of the dot at the end. Also, your download link on your blogsite does not appear to be working either.
K, the link has been changed on my Blogspot to get the tutorial. Thanks for the heads up!
A direct link to it is:
http://danjasker.blogspot.com/2008/06/fw5-cms-made-simple-template.html
Enjoy!
Hi Dan, I’d like to download your screen cast on how to build a template but MediaFire keeps telling me the password is invalid, please try again. I’m using apple as the password.
thanks
Sorry, i must have tossed the wrong password on there since I just redid the sample files for those.
Try again, it should work with the “apple” password.
Does anybody have the great tutorial from Dan anymore? i’m looking for it and can’t find it anywhere anymore…
I would realy be happy to read it once more.
Eugenie
I don’t even have it, but at the same time it wasn’t a proud achievement either. The screencast by now would be dated material and there are obviously better CMS systems out there.
I did get your email Eugenie, just hadn’t time to get back to you about it.
thanks Dan, i wasn’t sure you received it,and i don’t want to be the stalking type.
I have to have use this and have no idea where to start … and then i remembered your tutorial. To be honest…
considering the time that has been over it… it was great for that time… ![]()
kick up… perhaps someone has got it on backup somewhere??
Tim and Remco… Thank you so much for your help!!! stil do not like this cms, love the wepyep to much! ( specialy with the explaining tuts from Dan!) but i have the video now and can work on it. Thanks so much!!
Eugenie
Hi
i want to know how to add categories and products in CMS made simple.
i urgently need help regarding this.
Thanks & Regards
