This particular code would go well in an inline Markup Item. To do this with some style, double-click into an HTML box where you want the button to appear, type two spaces, then press the left arrow key to move back between the two spaces. From the main menu, choose Insert / Markup Item, and paste the code into the dialog that appears. When you Okay the dialog, you will see a tiny [ < H > ] box inline in the paragraph of text where you started. Select the entire space/markup/space “sandwich” and apply your desired text style to it.
On Feb 2, 2014, at 3:19 PM, John Robinson wrote:
Does anyone have suggestion for this? Would I just copy the code in the link or use the copy html action?
Thanks John
