I just noticed that since updating to snow leopard, suddenly the color doesn’t look the same, the colors look sort of grayed out on the object compared to the pallet swatch… Has anybody else experienced this and / or has a suggestion?
has a suggestion?
Yes, there’s a problem with the colour picker and SL. It was raised in an
earlier thread. Awaiting a fix?
Hi Fred,
Thanks for your reply. Is there a fix? I’d like to try it, or do you
mean you are also looking for a solution?
I looked for the thread you mentioned, maybe it’s got a different subject
line…
I’m also looking for a solution.
It’s odd but I can’t find that thread now either. However, open the fill
window and select ‘Paint’. From the colour wheel try to select a bright
colour. You can’t. This has been the case since the introduction of Snow
Leopard.
Hi Fred,
line…
Leopard.
looking at it a bit closer makes me think this is not exactly the
thread…
I googled “intaglio colour leopard julius” and that’s what came up
but I think it’s close enough
Julius
My experience is actually varied. I had that problem with a drawing I created using a jpg image I worked on with a demo version of Pixilmator. Then new drawings began having that problem as well. Then I re-started Intaglio fresh, re-worked an older drawing with all proper colors, and suddenly it’s over- no more problem.
Later I used the same photo, loaded it onto an older drawing, and everything works fine. It looks like my new drawings are working good as new!
