What is going to be the best final process to convert previous FW4Pro
files into the FW5Pro version? I have been working with smaller
sites from the start of beta, but I have a bigger one that I want a
smooth transition with into the final 5 release.
i’m still working on that problem to. with very wett hands, because my core solo does not (read NOT ) want to ‘do’ fw5.
and my core duo does not do my cs3 suit…
no, my licence for the cs3 is not for the core duo. but the problem is, that i try to make my freeway files in fw5 on the ‘normal g5’ ( not core duo ) and it won’t work. The spinning wheel keeps spinning and just goes on.
when i install the fw 5 on my core duo, NO problem.
i have my freeway files on my normal g5, don’t ask me why, its a personal thing! i don’t like working on my other mac, i use it as a expensive windows machine.
But now i am forced to keep using fw 4! cause 5 just won’t work. I have asked the help desk 2 now in an email, but no answer yet!
( not the first time )
boy i hope, this is a bug and it has a sollution…
Your license for CS3 is not for the core duo? The CS3 license is not Mac model specific so it should install on any “Intel” Mac without a problem. There is only an issue if you try to install it on more than one Mac that is networked as the installer will find copies of itself.
The “core duo” moniker only applies to Intel processor Macs. If you have a G5 dual processor, that is a completely different beast hardware wise. Even so, FW5 should run on either platform; PPC or Intel processor. I have it running on a G4 and an Intel CoreDuo Mac Pro. Runs fine on both.
Actually, the software has to be activated. This can be done on two
different machines, with the agreement being that you won’t use it on
both at once.
You should be able to install and activate it on the single-core
machine as well as on the core duo Mac. And you should also be able
to run Freeway 5 on either Mac as well. If you really can’t run
Freeay 5, one possible reason could be that you have something up
with the system itself on that Mac.
nope. it installes nicely on my ppc, but it woun’t run my fw 4 files. that is my main problem!
and yes the networked issue ! i have it installed on the ppc and had it befor i had the intel processor based mac. so …
but that should not have to be an issue at all.
i like working on my ppc. i love it! my programmes are installed nicely on it, it workes, its good. ( never changes a winning team LOL )
but i don’t understand why my fw4 files won’t work on the fw5 copy i have! i hope that when in 8 days the ‘real’ thing comes, they will do!
I have FW5 installed on a PPC (G5 1.8) and it opens FW4 files without
any problem at all – only a tiny bit of styles correction for some
pages that dated back to FW3.5 initially.
Steve.
Steve Cooper, email@hidden
Mac Assist, Geelong Australia
Web: www.macassist.net.au
