to appear inside the code Freeway generates for the flash file.
Anyone want to chip in? feel free.
On 3 Nov 2008, at 16:33, Eelco Deuling wrote:
Yes, thank you. However, this wont work.
There is a diffirent portion of code in your freeway example:
This code is from the transparant example:
swfobject.embedSWF("Carousel.swf", "carousel1", "100%", "100%",
"9.0.0", false, {xmlfile:"default.xml", loaderColor:"0xCCCCCC"},
{wmode: "transparent"});
It seems there is a different sort of code to embed the swf file.
The important bit however (according to the explanation found on www.flshow.net
) is:
If i manualy change the code it works, even with the swf included
with your example so, its not in this file but in the code (and in
the code of the xml file).
I have to use HTML markup but there i get stuck: whatever i do it
wont work.
Maybe it is the code Freeway uses to embed the swf file.
I could use the Source code snooper action to change this but i was
wondering if it was possible to do it more gracefully?
...and excuse me for my terrible English: its disgusting, i know!
Much more gracefully than Source Code Snooper!
Select the SWF file
Choose Item > Extended (or type command-option-X)
With the ‘embed’ tab selected, click the ‘New’ button
Type “wmode” into the Name field and “transparent” into the Value
field. Without the quotes, naturally.
Freeway’s code for using SWF files won’t be the same as everyone
else’s - but that’s fine; there are multiple ways to do this. All you
need to do is add in the extended attributes for the embed tag and
they’ll be put into that long list of attributes that Freeway makes.
I do this to add the allowFullScreen=true attribute to my SWF
panoramas when I deliver them using Freeway. (Although I’ve taken to
doing it all in a lump of markup code instead because of a quirk
Freeway has in recognising files as being different or not. Long
story.)
Dear David,
it is wonderfull, funny and working n ow. looks just fine. i realy wanted to thnk you!!!
just one question… ( alway’s a ‘’‘just… isnt’ it?)
how do i get the links /urls to work?? it’s not important, but they don’t do anything LOL…
would be nice, but again, not important…and since your daddy-carousel-tut- now…thought i ask you…
have a great sunday…
and again, thanks for taking the time!
it realy is such a nice item.
Eus
David Owen
