I am thinking about getting FW pro. Was wondering:
Is it difficult to add quicktime movies to a page?
Can I have master pages that update all pages at once. In other words if I had some CSS menus on a master page, would it update all of the children pages with it?
No, we just drag movies straight to a page and they work. You may stumble into plugin issues though depending on the format.
Yes
Is it possible to add code to a page?
Yes, there is an Add HTML Markup item for embedding code (HTML, PHP etc)
