I’m curious if anyone else out there is having problems with Freeway 4.3.2 build 5449 crashing. I realize there can be many causes of this, but before I start analyzing the cause, I want to know if anyone else is experiencing this. I’m working hard on a complicated site creation and keep having crashes at least once a day. Don’t know what triggers it, but each time it happens I loose valuable work. I’ve resorted to editing all text to be used in Freeway in a TextEdit document then copying it into Freeway so I don’t loose it. One crash was so bad I could no longer open the file. I used the Freeway generated backup file and it was very outdated. I’ve resorted to doing hourly backups of the Freeway document to avoid loosing so much work. Anyone having same? Does version 4.4 help?
I am using 4.3.3 without any problems – hint, hint.
version 4.4 help?
I’d suggest updating to 4.4 as mentioned above, and also checking the Softpress Knowledgebase for suggestions on eliminating crashes. They’re usually caused by bad fonts or resources.
If you still have the crashes in 4.4, I’m sure Softpress support would love to know what causes them so they can be eliminated in future versions.
