purity
(purity)
February 28, 2016, 9:24am
1
Hello,
I’ve a problem with the header and footer width at the iPhone portrait breakpoint. At this breakpoint the width of the freeway site is set to 320pt. The two bars are cut off there and I can’t find the reason. The wrappers, where the content boxes of the header and footer are in, are set to available width and their childs, the content boxes, have at a fixed width.
You can find a screenshot of the situation here: Dropbox - Error - Simplify your life
Can somebody give me a hint what’s wrong?
Thanks in advance
Ray
http://www.plancfilm.com
The purpose of this topic is to provide information about the migration from FreewayTalk and Groups io to Discourse and the differences in Discourse, as well as a place to discuss the good or bad of the migration. For those previously subscribing...
Reading time: 2 mins 🕑
Likes: 1 ❤
The problem is that your youtube iFrame has a width of 350px - the headers are the correct width but the vid is making the ‘page’ wider.
Likes: 1 ❤
purity
(purity)
February 28, 2016, 10:20am
3
Hi David,
thank you for your answer, but it’s the same problem on pages without the video.
Like: PLAN C jobs
greets
ray
Likes: 1 ❤
Have a look at loopcontent - that extra 25px of padding is making it wider than the rest of the items.
25px padding is an extra 50px on the width.
Likes: 1 ❤
purity
(purity)
February 28, 2016, 1:41pm
5
Hi Dave, but the same padding is set at all other breakpoints too and there neither the header nor the footer is cropped. I need this space between the text and the content box border.
Greets
Ray
Likes: 1 ❤
Yes but the page width is wider than the box + padding at all other sizes.
Make the box a narrower width at this BP and keep your padding - 220px should do it.
purity
(purity)
February 28, 2016, 3:27pm
7
Hi Dave, thanks a lot. I will give it a try and report the result soon.
Greets Ray
Likes: 1 ❤
