CSS Menu problem
Hi, I have a CSS Menu on a site which is giving me problems.
The menus work perfectly OK except for when I am on an actual page
that the sub menu has taken me to. Once I have landed on the page
from the sub menu the CSS menu is dropping out the background and
hover colours.
Below is a link to work in progress . . . the live sub menu link is
‘organic’ under products and ‘mulberries’ under shop. You will see
that the menus look fine from the home page etc but when on the
products>organic or shop>mulberries pages the menus break or disappear.
Any suggestions or cures would be most appreciated . . . thanks in
advance for looking!
http://spacespider.co.uk/BETA/TBSC/index.html
Regards
Colin
This is because of the setting that you have used for ‘Current Page’ is different from the rest of your settings.
Have you no bg colour set?
If you uncheck the ‘Highlight Current Page’ checkbox your problem will disappear until you have fine tuned your settings.
You also appear to be using 2 overlapping CSS menus - is this deliberate?
Yes as I wanted the sub menu on the shop tab to be a different colour. Also, due to the coloured button backgrounds and the width the CSS menu didn’t seem to align with the colours so these seemed an easy work around. If there’s a better way I’m always keen to learn!!
Colin
Hi Dave
Your a star, thanks for that . . . can’t believe I missed it!! Spent
a good couple hours getting frustrated going round in circles and
all I had to do was uncheck a box!!
Thanks again . . . Colin
