Hi
I have a CSS menu and I was wondering if it is possible to use a hyperlink to trigger a show/hide layer. So 1 item of the CSS menu has to trigger a hidden layer.
Thnx;
Yes - have a look at http://www.deltadesign.co/centred.html
Look at the first menu list pink>rollover me
To create this do your CSS menu as normal and click in your list where you want the rollover/link to appear.
Insert>Action Item>Text Rollover
Add the text you want in the action inspector and your target group etc.
With the action item selected Edit>Hyperlink and make your link in the normal way.
