I’m reworking my lad’s site, this page works just fine on Mac Safari &
Firefox:
http://dantucker.co.uk/test/landscape/index.html
But on PC/XP-Pro IE 7, Safari and Firefox, the CSS menu for Galleries is
obscured and the title “Landscape gallery” disappears.
All the page items are layered and the order looks sensible. It looks like
the Viewer item obscures the “Pagetitle” and “Menu”
Any ideas how I can fix??
Best wishes Peter
Peter Tucker, Oxford UK email@hidden
Hi Pete
It will be probably be down to your Flash, so try this…
Select the Flash item which in your case is the portfolio Item and go to the top menu: Menu>Item>Extended
Then in the dialog that appears, click New
then, in the next dialog that appears type wmode in the Name field
and transparent in the Value field.
You could also use opaque in that Value field too in you wanted but, transparent should be fine.
What should happen is once you have republished you should now see your drop down navigation.
all the best Max
on 02/02/2009 06:42, max at email@hidden wrote:
Hi Pete
down navigation.
all the best Max
Perfect. Many thanks Max ;~}}
Best wishes Peter
