Database Connection
hi
i am thinking in buy a Freeway Pro license but i have a doubt about database connection, is possible?
thanks
Hi Victor,
If you know it you can inject database connection code into a Freeway Pro page (before and after all the standard page tags, html, head, and body). You can also add code into the body tag (Markup items or this Action CrowBar - ActionsForge) to echo out your results.
If you don’t know the code, there’s also these Actions that could help you out:
http://actionsforge.com/actions/mysql-connect
http://actionsforge.com/actions/mysql-get-records
Hope this helps,
On 21 Apr 2015, at 08:50, Victor email@hidden wrote:
hi
thanks
i need a news section like a blog. is possible with Freeway ?
Not on its own but you can certainly integrate a CMS like Pulse http://www.pulsecms.com/ which has a Blog feature.
Is this for a client updatable Blog like feature, or just a client updatable section which you could also use the WebYep actions for WebYep Action - ActionsForge
