i am new to freeway pro. i have created a site my client likes very much. i adapted one of the templates pretty heavily the on thing i can’t change is this. In the template (floral) a graphics box sits on a background when opened up in a browser the box sits in a huge background yet when i try to increase the size of the box it overflows and wouldn’t publish. i know this is a novice question but i could not find anything to help in the tutorials
thanks in advance for any help
complement but i changed it a lot… but i just want to expand the box
so it appears larger on the background?
Thanks so much in advance
Rb
On Sep 3, 2008, at 1:24 PM, Dan J wrote:
Well I just downloaded the template and loaded it up. The only graphic items are the floral graphic text at the top and the side photo in the side-bar area. Everything else is an HTML item. If you’re talking about the big salmon (purple-ish) colored area I was able to click once on it and drag out height and width by grabbing the little Grey boxes in the corners. I published without a problem. You have to obviously move down the footer bar so it doesn’t overlap the salmon color.
Perhaps a test page in a subfolder somewhere might help out both with the changes you’ve made and find a better understanding of what you’re trying to do.
