Can I manually create/place my own DIVs throughout the design of a page so that I might want to use these DIV ids within Javascript for some further processing - if so, where?
Are there any good softpress sites that explains this further?
If you have the big blue CSS button on when you are drawing an HTML
box, or if you check the “Layer” checkbox in the inspector while an
HTML box is selected, then you have just created a DIV. The ID of
that DIV will appear in the Inspector, in the clumsily-labeled
“Title” field. You can change this to anything you like, and if you
try to create two DIVs on the same page with the same ID, Freeway
will change the last one to not conflict.
On May 4, 2008, at 11:25 AM, Tonsils wrote:
Hi,
