downloadable pdfs - still not working
I just can’t get downloadable pdfs to work on my website. I followed Walt’s instructions and created a text file (using Smultron) as follows:
<FilesMatch “*.pdf”>
ForceType application/octet-stream
Next I named it myfile and uploaded it to resource folder (where all the pdfs are). So far, so good.
Next I rename the file .htaccess
Next I fire up the browser (Safari) go to the website. Here’s where things go bad. The website comes up okay, but all the image files are missing. Granted, this is a step up from when I tried putting the .htaccess file in the root directory (in that test the whole website disappeared).
Any suggestions on what I am doing wrong?
Craig
Sorry, this is what the myfile looks like:
craig
Just out of curiosity try this instead (in the .htaccess file), without the ‘~~~~’,
<FilesMatch ".(?i:pdf)$">
/octet-
stream
Header set Content-
Disposition attachment
</FilesMatch>
And Tim has an Action if you have a php enabled server (all good hosts have them) http://actionsforge.com/projects/view/109-force-download-php
Todd,
Hey, that works!
Any idea why it works? Why doesn’t the FilesMatch *.pdf (which is spelled out in the SoftPress KnowledgeBase) work?
“<“FilesMatch “*.pdf””>”
“</“FilesMatch”>”
Thanks much!
Craig
Todd,
How were you able to type code into this box? When I typed mine in, everything disappeared between the “<” and “</”?
Dave,
Thanks for the PHP idea, I will look into that too.
Craig
I don’t understand the specifics of why it works. I have in the past successfully used the same example you tried so why it’s not working for you I can’t say. As is the case with many things there are multiple ways to achieve the desired result and there may very well be a better way than mine.
Just be sure to test it in a lot of browsers, including IE.
Thanks Dave, I appreciate your help.
