DTP Applications?
Being first a web designer, I’ve been asked to do some desktop publishing (more on a volunteer basis rather than professional). I’m curious as to what you all recommend for applications. Obviously, I’m looking for something affordable as I won’t be making money using it, but do appreciate good software. I do have a copy of Swift Publisher and iWork.
Depending on the specific project requirements either of those might be perfectly suitable for basic work. Swift Publisher is - for a hobbyist application - quite nice, actually. However, unless you are absolutely dead-set against using Adobe products I would say rent InDesign for a month and add the cost to your fee.
What Todd said - get InDesign from Adobe and add the monthly fee to your bill.
Marcel
Also, have a look at iStudio Publisher - http://www.istudiopublisher.com/
Lee
There’s QuarkXPress, of course (30-day demo available), iCalamus http://www.macupdate.com/app/mac/22953/icalamus and the open source Scribus http://www.scribus.net/canvas/Scribus. Older versions of InDesign may work OK with current OS (the CS5.5 version is fine with 10.9, for example), although still not cheap.
Roger
Roger Houghton
22 New King Street
Bath, Somerset, UK
Lee
I thought you could now download CS3 for free from Adobe?
http://www.printlineadvertising.co.uk
I recall that Abobe switched off the licensing server for CS2 so that if you had a serial number for that version of the suite you could activate it without it being checked. I’m not sure if I’ve seen this for CS3 but I wouldn’t be surprised.
A quick Google provided this article although I’ve no idea if it is still valid (YMMV);
Thanks all for the feedback! I assumed that there were a lot of options, but just didn’t know where to look first. Time to start taking them for a spin. :slight_smile:
+1 for InDesign
