Easy web animator
Hi all. I am making a simple splash page with a simple animation or really elements that appear one at a time.
I normally set up a page sequence timer/ target show layer actions for the elements. and it works fine, but I wonder
if easy web animator would give it a better punch. and if so,
I want to make sure that it is an html platform so we are able to view on mobile devices.
I am not a fan of flash, or movement, but in this instance I
have been asked to do it.
Thx all
C
Hi Carla, I’ve recently completed:
http://www.shorestone.co.uk
using Hype for the animations. HTML5, so works on iPads & phones and I’m very pleased with the results it churns out.
BTW, it may look a bit odd from time to time at the moment as it’s a WebYep site and the client is busy amending as it’s live!
Thx all
C
