I’m building a website for fine art printing where the customer will upload after paying, a file to Ecwid’s servers, where upon, the file will be downloaded to the customer.
I’m awaiting a reply from Ecwid to determine if they scan these files for viruses, I would appreciate any suggestions on what the client should do to minimize problems.
What I have done for public upload sites is the following: I accept
the file as an upload into the /tmp folder (basically where all files
go when they are uploaded). Then I try running the photo through
ImageMagick and make a thumbnail of it (ostensibly to show to the
customer, so they can say – yup, that’s mine). If ImageMagick blows
up on the conversion, then you can bet money it’s not an image file.
So if that happens, I delete the original file.
On Apr 21, 2011, at 12:42 PM, Bryan Irvine wrote:
Hi all!
http://www.entropy.ch for Marc Liyanage’s easy installer, I think. But
you have to install it on your server, not your Mac. (Marc’s installer
works great on the Mac OS X Server, though.) If you’re on a public
server, most of them have ImageMagick already installed. Get to a
shell on the server, and type
convert
at the prompt. If you get a Command not found error, then you will
have to install it, but if you get a version number and whatnot, then
you have it already and you shouldn’t try to install another version.
On Apr 21, 2011, at 1:27 PM, Bryan Irvine wrote:
Thanks Walt. Now my eyes are starting to glaze over attempting to
install imagemagick!
