Embed 3d viewer
Any recommendations on how to embed a 3D model on my website?
Hi Mark,
I think this would typically be done using iframes or markup items.
What are you using to generate the 3D model? Does this generate web output (which you can then add within Xway)?
These are the formats to which I can export. Thanks
I don’t see this option in your screenshot, but the Vectorworks website has a section on Exporting web views.
