Slowly but surely learning inline construction and to practice am building a simple, one-page site for a product I’m developing. Though I have other design questions for later, currently I’m running into an issue where adding two Exhibeo Thumblie galleries to the same page breaks the Smooth Scroll Action. Deleting one reinstates the Smooth Scroll, adding it back breaks it. The example site (godamat.com) has Smooth Scroll applied as well as two Exhibeo Thumblie Galleries. Smooth Scroll is non-existent, and some anchor/link relationships seem to be broken as well. Is it simply asking too much to have all three work on the same page or is there a way around it? Also is this a broader problem with having multiple Exhibeo galleries on the same page? That will be a huge limit for other sites I’m designing. Thanks all in advance!
www.godamat.com
Exhibeo mailing list
On 22 Dec 2014, at 09:17, Donna Rooney email@hidden wrote:
www.godamat.com http://www.godamat.com/
If you sell this product in Sweden — with I hope you will
some day — be sure to expect som confusion in the name!
”Goda” in Swedish means something that i tasty to eat….
As if that was nit bad enough, ”mat” means food…!
Cheers! Arne Gustafsson
Thanks, Arne – Well aware of the translation… the name sprung from the dog training command “go to mat”… as a professional cook, I like the idea that it also can mean tasty food. And who knows, maybe there’s another product line idea in there too!
I think your problem here are conflicting script libraries, used by the
different actions you are using. Which uses what, I’m not exactly sure… you
may have to pull some out and do some experimenting to find the conflict.
Then you will have to experiment to find a non-action way of implementing
any lost functionality.
