I am using Exhibeo to display a selection of photos within the Linked website and i cannot get the background colour specified within Exhibeo to match the window colour as specified in FW The colour in question is RGB - 0,51,102. and you can see the effect (albeit not very clearly) if you look at the link provided. There is a little “blue” border around the Photo stack which shows the issue… this Blue should be the same colour as the rest of the page. On this Exhibeo display the issue is not that great but when i use other Exhibeo display options the problem is very noticeable.
I have tried to identify the colour that Exhibeo is using and it is somewhere around RGB 2,36,83
What am i doing wrong please?
Thx
John
http://www.glandoreyc.com/squibsouthcoast.html
Exhibeo mailing list
John - I don’t understand…
If your FWP background color is RGB 0,51,102 and your Exhibeo border color
is 2,36,83 - those are two different colors… they must be the same numbers
to be the same color.
What is it you want to happen? What are you trying to achieve? The same
background color in the exhibeo gallery background? For the initial
thumbnail border color to be same as the FWP background color, so to blend
in? Why not simply set the initial thumbnail width to zero?
Also, which version of Exhibeo are you using?
Thx
John
Ernie,
I did not input the RGB 2.36.83,
The value i used for the background in Exhibeo is RGB 0,51,102
All borders are set to Zero
The version of Exhibeo is 1.1.2
Basically i am trying to display the images with no different colours around them
Thx
John
Thanks for the extra input John - this helps me understand your problem
much better.
I’ve set up a simple example using your color (RGB 0, 51, 102) and I can
verify that Exhibeo IS changing the color from rgba( 0, 51, 102, 1.00 ) to
rgba( 2, 36, 82, 1.00 )
http://cssway.thebigerns.com/workbench/exhibeo-johns-bloxx-borders/
The color can be hacked through the exhibeo CSS file, but this appears to
be a bug and should be submitted to Softpress for resolution.
On Mon, Jul 28, 2014 at 12:41 PM, ejw email@hidden wrote:
Ernie,
around them
Thx
John
Ernie,
Many thanks i will submit a report and refer to this thread.
A little bit of satisfaction that i wasn’t being totally novice again !!!
Thank You
John
