To use the Exhibeo import action all you do is Insert>Action Item>Exhibeo Import
This will give you an instance on the FW page - with it selected look in the Action Inspector and in there you choose the Exhibeo Output File that you created.
Of course you need to output the files from the Exhibeo App first.
You can download the FW action from there as well (if you haven’t done so already)
Oh, and to get the permission to post on the Exhibeo list, just check the appropriate box to add it to your subscriptions here: http://freewaytalk.net/person/options and press the Update Memberships button.
