I have placed an Exhibeo element (Slide) on this page but I can only scroll past it on an iPhone if my finger is to one side of the slide show but not when on the Exbibeo element itself. Which is not ideal with an almost full width element. Have looked at the Softpress Exhibeo page and of the examples there Slide and Impress behave in the same way. Is there solution or is that the way it is ?
Thanks for your feedback. We’ve logged the issue here.
Sorry about that!
Hi all I just ran into the same problem with exhibeo.and it will not allow fingers to scroll below it on an iPhone. I just went live with the website and this is quite serious . does anyone have a fix for this… oh buy… what a conundrum, thx
Exhibeo mailing list
If you have Exhibeo 1 still lying around somewhere, you could consider using that.
Exhibeo 2 -as has been reported since its release 1,5 years ago- is a buggy and incomplete app which does not work the way it should. There haven’t been any fixes and neither are there workarounds. I fully recommend Coffeecup’s Responsive Content Slider which does an amazing job and is quite affordable.
– Richard
Yes, you’d have to add some lines of code via HTML page markup as well as via Insert markup item and upload the resources manually via your favourite FTP client.
A couple of the good things of Coffeecup RCS are the possibility of usage of HTML text and the responsive slides you can create by good use of your breakpoints.
– Richard
ah well it worked for a minute… so I have 2 slideshows in one body wrapper, one with exhibeo 2 in one Div and Exbibeo 1 in another Div wrapper… who knew you cannot use both on one page?? me
Sorry I meant thx Richard, ok so I went back to Exhibeo 1 for both desktop and mobile output, but alas - having multiple exhibeo 1 galleries does not work as it does with Ex2. is there a work around on this one? anyone
Actually having 2 exhibeo 1 galleries is fine in one body… just in case anyone else runs into the same issue. Please note that one gallery is displayed on mobile BP and the other is displayed on desktop, so all went well… my mistake was not applying the Exhibeo import action, … now its working
anyway Thx Richard
