Export HTML problem
I’ve found the trigger which is if the initial thumbnail fills the width of the page, an error will occur during calculation for thumbnail grid sizing. I’ll look at a proper fix for this problem but in the meantime, you can work around it by reducing the thumbnail scale setting.
  • Open Exhibeo document
  • Show the theme settings
  • Expand Document Settings
  • Reduce Thumbnail Scale to 180%
This should make max-width small enough that it won’t trigger the problem on the vast majority of devices.
