[Express] Borders and Click Mouseovers
I’m adding a Freeway page to an old GoLive site, and trying to make things match. Two issues:
(1) GoLive had the option of nice bevelled borders for boxes. Can you do this in Freeway?
(2) In Freeway, is it possible to have a rollover where the appearance of a target image is initiated by a click on a trigger image, but reverts when the cursor is taken off the trigger image?
With thanks,
Paul
Do you mean tables - such as at http://www.deltadesign.co/fw_examples/tableborder.html
This is a standard table cell with 10px border
Strictly speaking this isn’t a Rollover but an onclick event. Do you mean that you want the image to change only on mousedown?
This example shows the setting of the Click state http://www.deltadesign.co/fw_examples/rollclick.html but this is usually accompanied by doing something else ie moving to a linked page and isn’t reset if you stay on the same page.
Thanks David for your reply.
I did mean box, but a single table cell would serve the purpose, and does have a nice bevelled border!
For the other problem see
The text icon at bottom right produces text in the central box when clicked; this text vanished when the cursor moves off the icon.
In later similar websites, I have gone with the straight rollover, but I’d like to match the behaviour of other pages on this site.
Cheers,
Paul
Hmmm - not sure that that does it for me. A bit disconcerting for the text to disappear when you move the mouse after a Click.
To be honest I am not sure whether Express is up for this. Not being an Express user I don’t know whether there is an action that can do it.
In Pro I would suggest using Target Show/hide layer but in Express i think you are limited to Target Show/Hide Image but it would be with a rollover rather than onclick.
