I’m using Freeway Express, and on my ‘contact’ page have some hyperlinks which are prompting thus on the Usability Report;
Links on map areas must be repeated on text - any links should be accessible on HTML text as well as image map areas to help those using screen readers to navigate.
How do I sort this?
Also, I have several hyperlink rollovers set up, all seemingly exactly the same. Those that go to e-mail addresses behave exactly as I’d like. Those that go to web sites behave OK under ‘normal’ and ‘mouse over’, but on ‘click’ have a kind of uneven light blue box around them. Can’t find anything in the way I’ve set them up any different from the ones I’m happy with. Any ideas?
Thanks so much for your help.
