H.Banken
(H.Banken)
March 5, 2013, 4:48pm
1
There is a problem with the Max Fancourt WebYep Menu CSS Styler:
I use the padding-left to intend my menu (e.g. 20 px). If i create a sub-sub menu entry, the indent for this entry is not as expected 20+20=40px but 0px.
How can i solve this?
Thank’s for response
Hubert
http://www.http ://spopi.de/Tests/WebYep/menu
Hi
unfortunately your link isn’t correct is there any chance I can see a page with menu
cheers max
Hi Max,
he maybe meant:
am not sure, but what if you add to the "submenu closed (Untermenu geschlossen) a 0px 0px 0px 20px?
This should add a padding-left to a submenu that has further entries. But can’t confirm if this is working.
H.Banken
(H.Banken)
March 6, 2013, 7:40am
5
Max: the Link Thomas posted, is correct. (copy&paste problem).
Thomas: i tried this, but it isn’t the solution.
The usage must be the WebYep Menu SCC Styler Action. If i don’t need this action, the intent is as expected.
Hubert
H.Banken
(H.Banken)
March 6, 2013, 9:07am
6
On 6 Mar 2013, 7:04 am, H.Banken wrote:
… WebYep Menu SCC Styler Action …
arrrggh: CSS
and: i use PRO and not EXPRESS
H.
hi hubert
can you click on the extra styles button and add these two extra styles in the popup window and do a complete publish
#MyMenu li li a.WebYepMenuTitle { padding:0px 0px 0px 20px; }
#MyMenu li li li a { padding:0px 0px 0px 40px; }
that should give you the extra indent you are looking for
all the best max
H.Banken
(H.Banken)
March 7, 2013, 7:27am
8
Hi Max,
work’s great.
Thank you
Hubert
