I would like it so that people can pause on mouseover, either with a fade in/out or sliding. So I tried this: http://www.jonhalvorsen.com/test3.html
with the mootool slideshow. Works exactly how I want it, but then the Target Show/Hide item with the rollover “Photography” item in the menu somehow doesn’t work. It shows all the time.
I also tried mootool accordion, look at the bottom to the left: http://www.jonhalvorsen.com/test2.html, but then I got a warning that mootool cannot co-exist, etc. Also I could not have different links on the popup line.
Basically what I want is the slideshow in “test3.html” with the menu bar in “people.html”.
I hope I made myself reasonably clear. Any suggestions to help solve the problems are most welcome. No rush.
This looks very promising and probably the perfect action to use. I will investigate by trial and error. If I run into problems I hope you will be able to come back with more useful information.
But relax for now, it is Saturday afternoon here in Palma and I will wind down…
