Does anyone have any tips on where to add the following code for fixed navigation within the Freeway doc using Backdraft in Freeway 6? Or another idea?
From a coder who develops websites. He added this to a demo version of a site I am designing and it worked for his demo but when I try it in freeway it doesn’t work.
I tried adding it into the code after I published freeway but it didn’t work and also not practical as Freeway will over ride the code if I make updates and publish the doc.
Thanks so much for getting back to me with the updated code.
I’m not sure the client would approve of me putting their site up before it is complete. The page is based on the Backdraft template (http://backdraft.onrampwebdesign.com/).
I can make a similar demo page with Freeway & Backdraft but I won’t be able to do that this week now as I now have another project to finish. I will try and post it next week so hopefully be in touch then.
In the site that you are building you would set the upload path as myownsite.com/clients/ with the normal user/pass combo that you use for your own site.
When you upload from the clients FW doc that you are working on it will populate the myownsite.com/clients folder (which is currently empty)
I cannot stress how absolutely essential it is to test your site as you are building it live on the server (using an assortment of Browsers and OS). It also makes it so much easier for us to diagnose any issues.
If you are worried about it being ‘found’ then use your hosting cPanel to password protect the directory so that only authorised viewers can see it.
I’m working on another site at the moment using the same BackDraft framework with Freeway Pro 6.0.2 as the one I mentioned in my earlier post. I’ve tried adding the code you suggested to this site (before the but the navigation is still scrolling up as before rather than a fixed navigation.
Here is the link.
I’ve added a class:NavigationWrapper to the NavigationWrapper Name/ID (in the inspector panel)
by clicking on “Item > Extended > and entering this in the
section”
Thanks again!
Best wishes
Mog
I tried using BackDraft with the Freeway 7 Upgrade demo version but the programme kept crashing. Also when the site was published, images would distort rather than resize properly.
BackDraft relies heavily on the Box Sizing action which doesn’t work in 7
2 - Not necessary to add the Class of NavigationWrapper - it does nothing.
Your main issue is that your javascript is working and adding/removing the 2 classes floating/fixed to NavigationWrapper but these styles are not declared in your page.
Take the following code and add it into Page>Html Markup in the before slot
Thanks so much for your help. This is working now but I notice is that when I stretch the browser larger than the design of the page, the navigation floats to the left and out of line with the rest of the page which is centred. Is there a way of keeping the navigation centred with the rest of the page when the browser expands?
I notice although your navigation bar also floats left, the grey bar background continues along the right hand side so gives the illusion it’s a bit more centred but I’m not sure how to do this.
I’ve just added this code to a new site I’m working on but can’t understand why it’s not working for this site. Could you let me know if I’ve missed something?
