There’s a typo in the script at the top of the page:
if(navigator.appName.indexOf"Microsoft Internet") == -1){
should be
if(navigator.appName.indexOf("Microsoft Internet") == -1){
Also, this entire block of script needs to be in the HEAD, not before
the HEAD starts. Cut everything to the clipboard, then change the
picker in the bottom-left corner of the HTML Markup dialog to read
“After HEAD” or “Before /HEAD” and paste it all back in there.
It looks as though you have everything right in your function call
except for the link. When I look at your published page, I see
a href="javascript:%3B" onclick="...
If you can somehow change that to javascript:; (the word javascript,
a colon, and a semicolon all in a row) then this should just work.
On Sep 22, 2008, at 2:47 PM, rebeccintosh wrote:
Hi Walter, I’m sorry, I had to jump and finish off two projects
before I continued on with the javascript - Flash issue.
I was messing around with it this weekend, but I’m still not
getting it to work, so if you happen to have an opportunity to look
at it, that would be great. I have everything set-up as discussed
above (graphic links to hyperlink). Flash movie is placed on page
with html box. I even have the ‘upload stuff’ action uploading the
swf file. The first action frame in my Flash movie is stop(), and
the next one is (play). Perhaps I have done something incorrect (or
haven’t done anything at all with the ‘ID’ name. I don’t know what
or where you would set that. When I hit the company logo to fire
the flash movie, nothing happens.
http://www.fonsecadesign.com/magbeta/
(it’s set-up just on the homepage right now)
thank you for all you help, Rebecca
