Flash & Smooth Scroll
Why do I need Flash to make Smooth Scroll and Anchors working in FF?
What makes you think you do?
Hi David
When I purge Flash from my Macbook Pro, Anchors and Scroll Down doesn’t work in FF but they do work in Safari…
Coincidental I think.
An example page we can look at?
HP below in Signature, Dave
Those of us on mail do not see your signature line in the message we receive. It’s always best (most universal) to type it into the body of your message.
Sorry, here we go: http://www.piranha-ag.ch
What I find strange is, when using the menu to go directly to Mobiler Dialog, the YouTube movie is on top of the menu when it appears or disappears. When scrolling manually, the menu is on top …
Richard
Is this movie a Flash object? It may be cutting through the visible page. See if you can set it to wmode=transparent, which triggers a better composition technique that doesn’t override CSS layering.
Richard
Not seeing any SmoothScroll issues with FF34 and no Flash
What I think you may be experiencing is a Javascript error that occurs if there in no Flash plug in enabled that then upsets the Smooth Scroll js too.
There is swobject.js on your page - probably helpfully provided by FW.
A better mind that mine will have an better explanation.
There is swobject.js on your page…
swfobject.js
Its’s been called for by :
script type=“text/javascript” src=“http://www.piranha-ag.ch/Kreativbanner/bzLoader.js
Open up the bzLoader.js … line 177 :
document.write(’<script type=“text/javascript” src="’+_urlBZ86A1A3BFCE9644CA9922+“swfobject.js”+’">’);
That’s all clear so far. The Banner is flash but should switch actually to HTML 5 if necessary. Richard: Youtube was on the top layer because you’ve visited the site while I was working on the mystery :o).
Hi Peter, that’s was not what I meant … YouTube was on top while using the navigation/menu, but NOT when you scrolled manually.
When it’s on top, it’s on top. When it’s not, it’s not … you’d think. But why is it on top when using the menu, while when you scroll back & forth manually it was NOT on top? That’s the mystery.
Richard
The Flash Rubbish is away now it works.
