Every time my slideshow transitions to a new slide the whole webpage
flickers… this is not acceptable and is very annoying. Any fixes for
this? Am I doing something wrong?
I understand why you may not want to share a link in a public forum… The
silence on this question is likely a public admission of “hey, we don’t
know either”, and since we can’t kick the tires or check it out ourselves,
then I think you must take your question directly to the manufacturer,
Softpress. They may want a link or for you to send your file in, but at
least they will be private about it.
Do you have a direct email I can send the link to, I can’t have this
website shown to the public just yet.
Exactly, it’s for a private venture with Non Discloser Agreements attached.
It’s strange, Firefox works like a charm but Safari flickers whenever the
slideshow transitions photos… smh. Wish i could figure this out, lots of
folks out there use Apple products.
@Tim I checked out that thread and tried the solution but it did not work…
Also, as far as my website goes, it has no text produced by Freeway Pro. Everything are graphic elements I created in photoshop so I don’t believe it’s an issue with Safari rendering text. It looks more like a refresh issue.
Every time the Exhibieo slideshow transitions the whole page flickers/ blinks as it it’s refreshing.
I know it has something to do with exhibeo because I have 2 slideshows on my home page. One is use as a banner just below my header and the second slideshow is used as an advertisement display of my different products.
Each time both of the slideshow transitions my page flickers 2 times really fast.
Help please.
Thanks.
P.S. I can’t post the link because of Non Disclosure Agreemets.
Hi Emanuel,
Can you create a simple example page that demonstrates the issue you are having and post it online somewhere? If you don’t have a hosting accost outside of your NDA agreement consider sharing the files on DropBox as we should be able to preview the page perfectly well there.
Try making the Exhibeo items Layers and bringing them both to the from of the page using Item>Bring to Front or Command-=
Ok Tim, I’ll see if I can send you a link directly outside the forum. By
the way, can I send it directly to you?
issue.
Please do. I’ve BCC’d you so you should have my email address in your inbox. Failing that you can get a contact email by looking at my profile on Freeway Talk.
