Floating Menu/item inside box model page
Getting a menu to sit at a fixed position in the browser winder is easy enough by toggling the “fixed in Window” in the inspector. The menu will travel down the browser as you scroll down the page content.
like this: CSS Floating Menu
What if you’re build a fully inline page (box model) where the page content is centred using margins :auto and your menu is now sitting in something like an inline #div id='“left-col” where ideally is needs to be but only fix to the height to stay inside that box.
Simply selecting “fixed in Window” takes it out of the centred div and fixes it to the browser top/right using the co-ordinates on the box.
Are there any tips/tricks workarounds if any to make this scenario to work?
Yes. Make a parent for your fixed menu element that is 100% wide and fixed in window, then insert your menu element inline within that box and set its margins to Auto. This will give you a vertically-fixed, horizontally-centered layout element. Just remember that the fixed element will cover any links or other controls that happen to fall behind it, even though the menu won’t appear to cover them.
That’s the issue; if the menu with a parent at 100% and centred is in-front, it covers any main content links and if behind the content covers the menu links
Using z-index just the menu item does not appear to be working. Does z-index only work up to the parent container?
Each parent sets a new local scope for z-index. Each index is relative to its nearest parent element, in other words. If you want the menu to float above all other content, then it needs to be a direct child of the PageDiv, and probably in the last place in source order, too. You could try using the left:50%, margin-left: -[50% of the menu width]px trick, see if that lets you set it centered and fixed. You’ll need to break out the calculator for this, and I can’t recall if Freeway lets you set the Left in % using the Inspector. You may have to do this in the Extended dialog, relying on the fact that if you set an attribute there it will overwrite whatever you’ve entered in the Inspector.
Before I check if this will work, is there a javascript method? Or would the same z-index issues apply?
JavaScript could be used to move the field out of the normal stacking order, but you’re just automating the HTML/CSS change that you could make in Freeway anyway, and forcing that change to happen each time the page loads, which is wasteful.
Fixed it…
Make the menu inline under the content on the freeway page all in a parent container. Then make the menu #menu-col position:fixed with the height set where the content starts in this case top:128px
http://www.printlineadvertising.co.uk/demo/fixed-menu/
No z-index needed.
Nice. For the record, I though you were trying to do something different – to center a fixed-position menu over the top of a centered page.
On Sep 17, 2012, at 12:44 PM, David Owen wrote:
Fixed it…
No z-index needed.
I haven’t read this thread thoroughly, but I have a fixed-window navigation
item on my cv-resume page:
http://portfolio.thebigerns.com/cv-resume/
The item is actually in-flow content in my inline structure page - fixed
with css thus:
#nav { position: fixed; float: left; width: 172px; margin-left: 20px;
margin-top: 40px; z-index: 100; }
On Mon, Sep 17, 2012 at 12:44 PM, David Owen <
email@hidden> wrote:
Fixed it…
No z-index needed.
Very cool, except if you scroll all the way to the bottom, where it covers the links in the bottom.
Thebigerns.com
with css thus:
Added a bit of padding at the bottom - and a dose of smooth scroll to make more sense for the user.
Thebigerns.com
with css thus:
Work in progress, Walter :slight_smile:
Can anyone suggest why the smooth scroll action disables the menu links after a scroll on iPad?
Nudging the page a little by hand activates the links again.
Sent from my iPad
Thebigerns.com
with css thus:
David, I found this too. My research indicates its a known IOS issue and
I’ve found no workaround yet.
On Mon, Sep 17, 2012 at 2:03 PM, David Owen <
Sent from my iPad
Must be, your portfolio has the same issue.
Sent from my iPad
Just when I though this is good to go IE spoils the party.
IE does not place the fixed menu 100px from the browser window top but 100px down from the parent div top
Does this need an IE conditional statement top: 0px or is something more solid be a fix?
 position:fixed; width:352px; overflow:visible; z-index:100; top:128px
Creative Design | Print Production | Web Design & Strategy | Domains & Web Hosting
Oops! so obvious - removing top: 128px fixes it in IE
