Font help
I do not understand that? When I go to choose a font I have Source Sans Pro Light as a separate typeface? And where do I add “Source Sans Pro”, sans serif; font-weight: 300
Font set?
Is that something Ernie is adding or is it part of the font name?My
background is print, so I’m really not familiar with how web fonts are used
and managed? Any help is appreciated.
Yes, Font Sets are arbitrarily named by whomever makes them. I, being
somewhat organized, label them so I understand they are webfonts (and
therefore require extra code in the document head). Others I may label as
“websafe” so I am reminded how I set the font cascade on those.
…Hopefully one or another of them will pipe up with the recipe.
My still unpolished instructions on just how to use Google webfonts AND
download (for free) the screen fonts AND use all that in Freeway Pro. -
http://cssway.thebigerns.com/workbench/google-fonts/
Yeah, I’m the same way. What’s the best place to learn about using web fonts? I’ve used Adobe TypeKit in the past, and I may again if I decide to go with the CC Subscription, but what about Google fonts?
I don’t care what it looks like loaccaly by the way just want it to woe when live?
Hi Justin,
Do the following:
  1. Open the Edit>Font Sets dialog
  2. Find your Source Sans Pro Light font set
  3. In the third cell, enter: “Source Sans Pro”, sans-serif; font-weight: 300
Ok the dialog and then try previewing it in the browser.
  1. In the third cell, enter: “Source Sans Pro”, sans-serif; font-weight:
    300
Don’t forget the quotes around “Source Sans Pro” - they’re important!!!
Kelly, try this - Thebigerns.com
Typekit is easy (and a much nicer interface for exploring and choosing).
Work a little at it and Google fonts can be easier, and coupled with
Skyfonts (also free) makes for an easier local workspace situation.
Also, have a look at Typecast (which seems to be doing the rounds at the minute). A handy little tool for testing typefaces from a bunch of different font services:
And based in sunny Northern Ireland!
Still not working
http://easthalldesign.com/dms/
Hi Justin,
I just had a quick look at the page and can see that there are some curly quotes in the CSS that are breaking it (my fault, I should have formatted it correctly here – I forgot you might be taking it from the web-based forum). Try this instead:
"Source Sans Pro", sans-serif; font-weight: 300
If they’re still coming out curly then just delete them and replace them with straight quotes.
On 7 Nov 2013, at 16:28, Joe Billings email@hidden wrote:
Hi Justin,
Do the following:
Nearly there! Look like normal font weight - I did add in extended font-weight normal to stop H1 making bold?
‘Normal’ and ‘bold’ are relative values… when adding an extended
font-weight property to your style rules regarding Google fonts, you should
use the specific weight value (e.g, “300”)
Also, if you’re not planning on using all three weights added in your head
code, go back to Google and uncheck the unused weights/styles and re-apply
the head code. It will keep you page loads trim.
Best!
Erns I did that - still not working please anyone know how to get Source Sans Pro Light work as an H1???
Im now on about font set 8 how do I delete all these??
Ok got it! Ignore any font weights. Just use font title in this case Source Sans Pro - then in the extended box add font-weight then use the code Google has used in the code in the head - so for Light is font-weight 300 and if ya wanna use bold then 700 these numbers are next to the fonts when you review them on Google fonts…
All this brings up an interesting question. If you’ve designed several websites using Adobe’s TypeKit and you let your subscript expire, what happens?
How do I remove all the font sets I created figuring this out?
Typekit, you must set the domains to use the font on… I always set the client and my development server. My subscription lapsed and I have only 1 client site using Typekit - that font set still works on my server and the client’s. Don’t know why.
Edit>Font Sets. Select the Font set you want to delete and use the - (minus) button at the bottom left of the window.
But of course you have found that by now.
